The birth splines operator allows particles to born uniformly across a spline, but is there a way to cluster them more towards either end of the spline?
Cheers!
06-11-2021, 04:55 AM
(This post was last modified: 06-11-2021, 04:55 AM by tyFlow.)
You can set knot type to tangent, then adjust the tangents to modify the spline interpolation in a way that biases spline interpolation segments towards either end, and then use a non-normalized interpolation mode in the Birth Splines operator to generate particles at those biased segment locations.
06-11-2021, 09:09 PM
(This post was last modified: 06-11-2021, 09:09 PM by tyFlow.)
You can do it with a straight spline...just ensure the tangents of the two end knots remain parallel to the span between them and the spline will remain straight, even though the interpolation of the spline with be biased towards either end (make sure you disable interpolation optimization in the interpolation rollout of the spline base object).
There's no other way to do this without coding it yourself in the script operator (which, for a spline with only 2 knots, wouldn't be that hard).
