Rotation&Scale TM issue
Hi!
Rotation and scale properties in custom properties TM are working together or not getting read together. Only Scale is read and rotation is resetted
I am attaching the file
Thank you
Nayan Bodawala
.max   RotationScaleIssue.max (Size: 696 KB / Downloads: 504)
Hi Nayan,
This is not a bug, but instead a quirk of your setup. You set your scale to 0,0,0 before interpolating back up...but a transform with zero scale also has zero rotation (they are related in a transform matrix...if you zero one out, the other is also zero'd out). This is more of a general math issue than something I can fix. The easy solution is to scale to a tiny value rather than zero (ex: 0.001, 0.001, 0.001)
(08-02-2021, 08:33 PM)tyFlow Wrote: Hi Nayan,
Thank you. My brain was telling me the same thing, but was not sure....your answer confirmed it.
But if I set and get individual channels, then its working.....like setting custom properties vector scale and rotation matrix - its working properly
