hi,Tyson!
Would you like to ask whether you consider adding "RGB" attribute to VDB?
In some projects, I want to make colored clouds, such as those with very rich colors in the universe. I tried the UVW method. After output, I used "vrayvolumegrid" to import, and found that UVW has no place to use. I found RGB attribute in vrayvolumegrid. I think adding "RGB" attribute to VDB should be perfectly integrated with vrayvolumegrid.
Later, I also tried to use the light color to change the color of the cloud, but this has great limitations and is not the color of the cloud itself.
I sincerely ask you to consider this demand.
thank you
thank you
