08-16-2021, 02:05 PM
I have been doing tests exporting both TyCaches and TySplineCaches into a VRayScene with mixed results. I need to do this in order to render in a Linux environment and so far this can only be achieved using Vray Standalone. Let me tell you about 2 simple cases:
-Is there a particular workflow I should be following or practices I should avoid?
-Are there any parameters I should be paying particular attention to in order to use this workflow successfully?
I know Chaos Group are more than aware of the existence of TyFlow, having tutorials on their website in where they use tyflow and have listed TyFlow as one of the compatible software with VRay. What I am not sure is about the limits of that compatibility. I would appreciate any help
Many thanks,
Jordi
- In one of my tests 600 instances of geospheres where cached with TyCache along with their 600 trails using TyCache-TysplineCache-TySplineMesher. The scene along with other moving objects was converted in a few seconds into a VRayScene and submited to the farm (both managed by Deadline's VRay Standalone workflow). In this case the TyCached geospheres rendered fine as did the other normal geo, but not the splines, which were not shown at all in the render.
- On another occasion I have used TyCache in the same way to render about 2000 animated geospheres. 400 frames where exported into the VRayScene, but all of them were rendering the same first frame of the cached animation. I kept the same procedure as I used on example 1 to create caches, export and use the same VRay Standalone route. No clue on why this time not even the TyCache objects are failing to render correctly as in they did in the case above.
Many thanks,
Jordi
