HI,Tyson!
In my mind, tyflow is not a simple particle plug-in, but a programmed tool, so tyflow is not limited to particle animation. In the face of some procedural modeling work, I will not hesitate to use tyflow to make procedural models, because it is very convenient and fast to modify.
It is also hoped that the "Boolean" operator will be added to the operator, and more emphasis will be placed on procedural modeling. thank you
Now, if you need to do "Boolean" operation, you need to use VDB. Although VDB is very good, it is voxel mode, which is difficult to operate in a larger range,
