Rotation_ The neighbor align attribute does not seem to
HI,Tyson!
Rotation_ The neighbor align attribute does not seem to work.
thank you
Hi cgdvs, I think that's because that mode only affects particles in the same event. Since Event002 has only 1 particle, the particle has no neighbors.
I will look into it and if that's the case, expand the options to include particles from other events as well.
OK, I see. Because I see that there is a group attribute, I guess it may support other unrelated events. thank you.
Hi cgdvs,
I revisited this file and it turns out the issue is actually caused by a bug Smile
It will be fixed in the next build.
