tyPreview batch processing and alpha channel
1. tyPreview batch processing
The start frame and end frame of the camera can be automatically obtained as the time range, so if there are multiple cameras in a scene but different time ranges, there is no need to set the time range for each!
2. It can support exporting video files with Alpha channel as background
1) What do you mean "start frame and end frame of the camera"? Do you mean the first and last keyframe of its motion?
2) Unfortunately .mp4 (the only supported video file format of tyPreview) does not support alpha. If you want alpha you will have to export as image sequences.
(09-16-2021, 04:48 AM)tyFlow Wrote: 1) What do you mean "start frame and end frame of the camera"? Do you mean the first and last keyframe of its motion?
1) yes
2) mov??
(09-15-2021, 08:14 AM)feitianw Wrote: 1. tyPreview batch processing
Yes, I need this, too
