ExportParticles geo
1.No material options are available in the object cache
2.Export multiple objects at once, and each object is used as a separate cache sequence file,
.max   ExportParticles get mat.max (Size: 64 KB / Downloads: 400)
Sorry, I'm not really sure what you're asking for here.
(09-16-2021, 05:05 AM)tyFlow Wrote: Sorry, I'm not really sure what you're asking for here.
For example, I have multiple tyflow objects, and I need to export them to tyCache at one time, but the tyCache objects are all separate objects
You can't export multiple separate flows at the same time, but if you really need them together, you can bring them all into the same flow with Birth Flow/Flow Update operators and export from there.
(01-25-2022, 02:33 AM)tyFlow Wrote: You can't export multiple separate flows at the same time, but if you really need them together, you can bring them all into the same flow with Birth Flow/Flow Update operators and export from there.
After doing this, tycache cannot be retimed alone
