HI.Tyson!
The export particles operator adds an inherited scene object material export.
I often use the export particles operator to export object animation. Because tycache is small and fast. And suitable for rendering. So I tested many places and found that when multiple animated objects need to be exported, they cannot inherit materials, which is troublesome. Therefore, you want to inherit the material of the exported object and merge it into a multi-dimensional sub material when exporting the object animation.
thank you
In the actual project, there are many problems in ABC format and Vray agent. I see tycache is very good. It has the advantages of the above two formats, and is faster and smaller. So I want to use tycache uniformly in the future projects. In terms of process, only material inheritance is needed
thank you
