OpenCL crashed, GPU acceleration is disabled
I have this when I open the editor.
I am using the latest drivers the latest TyFlow and I have downloaded the latest CUDA dlls.
I am using a 3090 gpu.
What could cause this and how can I solve it?
You'll need to post more info about your scene. Also check the MAXScript listener for more info about what the error is when the crash occurs.
(10-11-2021, 04:27 AM)tyFlow Wrote: You'll need to post more info about your scene. Also check the MAXScript listener for more info about what the error is when the crash occurs.
At the moment I found that if I have only the cubla*_11.dll(s) then I have the issue.
If I have the cubla*_10.dlls as well, there is no issue.
I do not know why.
What version of tyFlow are you using?
(10-11-2021, 02:07 PM)tyFlow Wrote: What version of tyFlow are you using?
0.16129
I think it had to do that I load a file that was created in an older version and then the cubla*_10.dlls was in use.
But when I deleted the 10s and leave only the 11s and created a new tyflow scene it didn't say any "OpenCL crashed, GPU acceleration is disabled"
So I am guessing its because of that.
Still I am not sure.
Newer versions rely on the CUDA 11 DLLs, yes.
