11-17-2021, 10:51 AM
Hi!
It would be very cool, if we coud use point 3 values for Set target operator.
So that it would be possible that you can e.g. set closest particles with a specific color (R,G,B) as target. Or other point 3 values like XYZ coords, Euler Anges, Velocities etc.
Currently we can only use custom float, which is limited to one value.
Example would be, when I want to use find target operator to let all red particles move to the closest green particles. But a fixed value for green wouldn't be enough so we neet value ranges to be accepted for targeting. Green range starts at the yellowish greens and goes up to the blueish cyan-greens.
Same for the red particles for which I want to set the green targets. Red starts at the blueish purple values and goes up to the yellowish orange values.
Thank you and greetings!
