birth voxel and shell
hey there,
I came across an issue where if I use shell to any close object I dont get proper birth voxel, what I expect
for e.g. if a shell modifier is applied to a torus object,  it will be like a pipe and will be hollow inside and volume would be the thickness of torus - so technically birth voxel should birth particles inside the thickness volume, instead birth voxel birth particle to the whole object
Please look into it
Thank you
Nayan Bodawala
Hey Nayan,
Can you post a file or image of what you mean?
Heres the file......I have sliced the torus for preview purpose only.....If you see birth voxel doesnt respect shell, instead it birth particles in overall volume
.max   birthvoxel&Shell.max (Size: 632 KB / Downloads: 296)
Ah, I see what's happening.
By default, to speed up sub-element processing, the Birth Voxels operator splits up a mesh and processes its elements separately. Normally this makes it run faster on complex meshes but in your case, since the inside/outside are each independent surfaces, it's splitting up your shelled torus into two distinct non-shelled toruses and then filling them separately...which is why you're losing the holes. In the next build I will make element splitting optional, allowing you to get the shelled result in your scene.
(11-26-2021, 06:13 AM)tyFlow Wrote: Ah, I see what's happening.
thank you
