Hey
I have a problem with the use of particles from one tyflow in another.
I made a particle that will be a source for smoke simulation, but I would like to change the same particle system to RBD at some point and that it simulates in its own way. What I care about is one tyflow with a particle system that will later be the particle source in many other events. In my case it is an explosion of smoke in the window and when the particles are pressed into the box, they are converted to debris.
I have tried two options and both are not perfect:
1. I generate particles on the same source as the main particle system and I use "particle force" to keep their movement close to the main one.
2. I generate particles with birth flow and I remove them with time test when their age is greater than 0. Here I have a problem with the fact that the particles in the new tyflow are not in the same place as the source.
I'm pretty sure I'm skipping some little button that changes everything
help.
help.
