Material Operator
I'm having issues with the Material Op
1. The material operator is not assigning a material
2. If I assign a material to the TyFlow Icon that is the only material that I can use and it's stuck there overtaking the material operator, (I guess) unless I use maxscript to define the material as undefined. Then the only thing that renders is the object color.
As explained in the info box of the material operator, it only applied to VRay Instances.
If you want a material on your particles, assign the material to the tyFlow object itself. If you want multiple materials, assign a multi-sub material and set material IDs on your particles to differentiate.
(04-08-2019, 10:44 PM)tyFlow Wrote: As explained in the info box of the material operator, it only applied to VRay Instances.
Got it.
I'll dive in and arrange the materials.
A
