Incredible plugin you've got here! I'm very familiar with PFLow from back in the day but stopped using it for probably the same reasons tyFlow exists
My problem: I've got a skinned particle rig, all working fine and I can deform it with PhysX bodies from within the same flow as expected, but what I can't figure out is how to fire particles at it from another flow and deform it that way. I've read the docs, Googled, scoured the forums and tried a few different suggested approaches including using Birth Flow and Actor operators but I can't figure it out. Pretty sure I must've been very close a few times but had a setting or two wrong.
I'd be eternally grateful if someone could point me in the right direction, cheers!
