Broken by birth ID
[translated by admin]
I want to select birth ID 1, 2, 3-20, 30, 50, 80-85, 94, 96, 98
This condition is broken, but the attribute test can only test one ID particle. How to add this condition at once?
You can use a Script operator, and check them using regular if/else conditions.
Example (snipped):
Code:
var id = tf.GetID(sInx);
if (id == 1 || id == 2 || (id >= 3 && id <= 20) || id == 30 ......etc etc)
    //do work
(12-13-2021, 06:01 PM)流量 Wrote: 您可以使用 Script 运算符,并使用常规 if/else 条件检查它们。
示例(剪下):
Code:
    //do work
如果是单数或偶数怎么办
