tyPreview- Viewport Clipping
Hello!
I wish tyPreview supported viewport clipping! When I do some simple animation in a view, I want to be able to output the animation at any time to see the effect. I don't care about the yellow line/arrow on the right side of the view. If you use the camera view clipping tool or the legacy previewer, it can be cumbersome to set up and you lose the convenience of tyPreview. You can document this feature when you publish it: this feature does not support hiding the yellow line/arrow on the right side of the view.
Thank you very much!
Check this thread: https://forum.tyflow.com/thread-1657.html
(12-15-2021, 12:21 PM)HammerON Wrote: Check this thread: https://forum.tyflow.com/thread-1657.html
Thanks for your help, I have seen all these posts before, but I still hope tyPreview can add this feature. At present, what the author is most worried about is that the yellow line/arrow on the right side of the view cannot be removed after this function is added, but I think most people will not care about this problem.
