velocity multiply
hi,
I want to multilly velocity strenght and keep position.
vely slow moving particles are, but i want to set strong motion blur.(VRay)
i have tryied C# script, but set strong velocity, and the positionis changed.
by the way, In houdini, it's very easy.(point wrangle example: @v*=5Wink
I'm good if get similar technique in tyFlow.
thanks
Code:
public void simulationStep()
    for (int i = 0; i < eventParticleCount; i++)
        int sInx = tf.GetSimIndex(i);
        float eventAge = tf.GetEventAge(sInx); //then we get each particle's event-age
        if (eventAge == 0)
            Point3 oriPos = tf.GetPos(sInx); //** ORIGINAL POSITION
            float velMult = 2; //** VELOVITY_Multiply
            tf.SetVel(sInx,tf.GetVel(sInx)*velMult);
            tf.SetPos(sInx, oriPos);
.max   tyFlow_propertyTransfer_v001.002.max (Size: 864 KB / Downloads: 181)
tyFlow instance moblur is calculated by measuring transform changes between time samples, so even if you could multiply velocity, it would have no effect if the change wasn't reflected by the position.
(01-20-2022, 02:59 AM)tyFlow Wrote: tyFlow instance moblur is calculated by measuring transform changes between time samples, so even if you could multiply velocity, it would have no effect if the change wasn't reflected by the position.
thanks your reply.
but that's unfotunate.
