Max Freezes on exit and reset
Hey Tyson
Using max 2018 if I have a tyflow in the scene, whenever I try exit max or reset the scene max stops responding.
Max stops responding if I try vrays interactive rendering.
Thanks Gavin, I'll look into it!
Hi Tyson
Just an update.
Fot the reset and closing max freeze, it appears to have something to do with the Cloth tyFlow_SoftBodies_001 example.
Looks like only happen when I have that open, other files appear to be fine at the moment.
Update 2
Also happens on this file...
...Said the attachment was to big, will see if I can strip it down a bit.
Ok, stripped it down.
hope it helps
.zip   hecticNineLogo_tyflow_v02_gj.zip (Size: 202.56 KB / Downloads: 361)
