02-15-2022, 04:54 PM
Hi! I can't find any information. Is it possible? I would like to convert tyspline to geometry because I need to do a cloud render )
Thank you )
Thank you )
Tyspline baking
Thank you )
02-15-2022, 05:07 PM
Export Particles > tyCache (splines)
02-15-2022, 05:38 PM
02-15-2022, 05:44 PM
Yes.
In case you're not using any features from the last few PRO builds (check the version history to see what was added to PRO), you can also revert to a beta build to export. Instructions for getting a past beta build are here: https://docs.tyflow.com/faq/beta
02-15-2022, 05:55 PM
(02-15-2022, 05:44 PM)tyFlow Wrote: Yes.Many thanks! You saved my project) It's great to have such active support on the forum)
02-16-2022, 02:57 PM
(02-15-2022, 05:44 PM)tyFlow Wrote: Yes.This created a tyCach object and a tySplineCache. How to create an object from this that will be read without tyFlow? Convert to regular animated mesh or splines. You need to send the file to the render farm, and for this you need to clear the scene from plugins. Sorry I'm new
02-16-2022, 03:00 PM
If you need to create a cache not dependent on plugins, then you'll have to export the mesh as Alembic or another native format to max.
