ParticleForce Not working properly - I think
Here the file i am uploading - please check, particle force is not working properly.....
Thank you
Nayan Bodawala
.max   ParticleForceIssue.max (Size: 732 KB / Downloads: 222)
Can you describe what the problem is?
(02-21-2022, 05:49 AM)tyFlow Wrote: Can you describe what the problem is?
The particle radius is not working the way it should be working......I have to increase fall off quite a bit to get the upres particle following the source particle....and by increasing fall off the whole upres looks different
Ah I see, hmm...I'll take a closer look when I get a chance, yes.
