Hi! I am position transferring my particles to another object, but the sibling index get messed up completely.....my original flow has sibling index which is used for spline generation, but in position transfer the sibling data is completely messed up...
Thank you
Nayan Bodawala
03-04-2022, 02:16 PM
(This post was last modified: 03-04-2022, 02:18 PM by tyFlow.)
Hey Nayan, Sibling relationships are not carried over between flows. I would recommend using Set Target in the first flow, and setting target by sibling, then using targets in the second flow instead to match up particles.
Perhaps bringing over sibling relationships between flows is something I will add in the future...I haven't figured out yet if it makes sense...
