Hello
Working on Tyflow Pro v00002. I have weird export behaviour.
I have got 7 separate crowd sims with actors under one Tyflow system.
I have also 7 separate export op's in each system with "Include actor skinned meshes" on.
All works fine but when it comes to export the operator exports all the meshes, even from different systems. Is that intentional ? Should use geos ID's ?
I have found a workaround, switch off meshes in Actor op and exporting one by one but it is not very optimal.
Is this intentional Tyson ?
Best
Chris
Best
Chris
