tyFlow v1.0054
tyFlow v1.0054 is up!
https://pro.tyflow.com
NOTE: as with the last build, this build features a full UI re-write...which means it may be unstable. If you need to revert back to v1.005, the download link for that build is still at the bottom of the regular tyFlow download page.
* (hopefully) fixed more issues related to the Shape operator (selections being weird, settings not changing properly, etc)
* fixed an issue where adjusting brush density from the Brush rollout in the Birth Paint operator would cause the density to change to 0
* fixed an issue where updating a tyCache asset path in Max's Asset Tracking dialog would not affect the tyCache object
* improved tySplineMesher knot alignment on closed splines (prevents mesh twists at beginning/end of loops)
