07-05-2022, 07:41 AM
HI,Tyson!
The "custom properties" operator affects one attribute of a particle to another in a relatively simple way (now there is only replacement mode). I wonder if I can refer to the mode in the "select" modifier ("set, add, subtract, multiply, invert selection"). In the "select" modifier, new layers can be added continuously, and different modes such as addition, subtraction, or replacement can be used between layers. This operation mode improves the degree of freedom and convenience of the select modifier.
If the mode of the "select" modifier can be transplanted to the "custom properties" operator, the flexibility of the "custom properties" operator will be greatly improved. Do you think it is feasible? thank you
