HI,Tyson!
The offset value of the "brick fracture" operator is locked (marked by the red box). I remember that the offset value in the UI can be adjusted before modifying the UI. Also, the "size" value has no effect (at the green box mark).
Please verify. thank you
In previous versions, "size" was gray before it was activated as "object". Now it can be adjusted directly, which gives people a misunderstanding.
