HI,Tyson
In "max2023", after I first opened Max and created tyflow, I found that tyflow often failed to load the registration information file. After I open "max2023" with "administrator identity", tyflow will change back to professional version. This is not a big problem, but I have encountered it many times. I hope you can investigate it in your spare time.I use a locked version
Supplementary note: this situation does not exist in other versions of Max, but is often encountered in the max2023 version
