Documentation - Displace Op
I don't know if you want to know about these minor things, because I am working on the new visual help PDF, I noticed this.
The noise text (section)(help) for this operator appears to be wrong. Nothing (parameters) matches the current noise rollout. I am assuming the current (text) information is from the old rollout, where it was all in one rollout.
The noise section is now a rollout and the text appearing in the online help appears to have same parameters as (noise rollout / turbulence (legacy) mode)
The rest of the text for this operator appears correct.
Rob
PS: Also Docs for Push operator - change text to say push rather than relax
Thanks, should be fixed now.
(08-04-2022, 06:08 PM)tyFlow Wrote: Thanks, should be fixed now.
ok - I was editing my post as you responded - push operator text needs to be change (change relax to push)
Cool, fixed as well.
