08-06-2022, 01:28 AM
tyFlow v1.008 is up!
https://pro.tyflow.com
* added Zhu-Bridson blobmesh mode to tyMesher and Particles to VDB operator
* updated OpenVDB library to version 9
* improved speed and dynamics of Birth Fluid and Fluid Force operators
* added built-in gravity and buoyancy forces to Fluid Force operator for spray/foam/bubbles
* added neighbor threshold options to Birth Fluid spray/foam/bubbles rollout
* added filters rollout to Position Object operator
* added Display Data operator option to show custom vector as a line in the viewport
* added options to filter PhoenixFD grid particles by type in the tyMesher blobmesh settings
* added dynamic fusion options to Fuse operator
* improved stability of Particle Physics' "attract" parameter
* fixed a regression where the Fluid Force operator wasn't properly loading or updating PhoenixFD grid particles
* fixed an issue with the Object Bind UI where the position bind velocity radiobuttons weren't working properly
