08-09-2022, 02:30 PM
I've always put turbosmooth on tyflow object and it do what i expect.
Now if I apply a turbosmooth to tyflow all the geometry disappear both in viewport and rendering.
I've noticed that if i Apply a Mesh node set to triangle mesh with render only unchecked it works fine both in viewport and in render.
Is this now the correct workflow or i miss something\doing something wrong?
If i check again render only the turbosmooth is not working enymore no matter if i uncheck it again. The only way is to delete it and reapply it.
Do not know if it is a bug or simply is how it works now. I report it cause it seams a strange behaviour to me.
Sorry if I miss something.
Thanks, Alessandro
Thanks, Alessandro
