The name of the tyactor animation sequence cannot be modified
HI,Tyson!
In the "tyactor001" help object, the "name" of the animation sequence cannot be modified. Please check it. Thank you
Hmmm...works fine here? Just have to click out of the edit text box before the change takes effect....
This is really strange. As you said, it can be edited. But I can't edit it just now. Maybe I made a mistake. sorry.
After repeated tests, I know why I can't modify it the first time.
It's because after I click here to activate, I accidentally set the Enter key once, and then I can't modify anything. At this time, you need to click other areas to activate the name modification here again before editing again.
Oh, interesting...when I follow those steps, I can reproduce the strange behavior (textbox seems to have focus, but doesn't take input). I'll look further into this issue...
