TyFlow Arnold properties
How can I use arnold properties with tyflow ?
Need to render a few passes but I'd need to add arnold properties to the particle system, couldn't yet find a way to do it.
Need help with this ASAP
If you add a mesh operator and turn off "render only", your Tyflow should be (at least from 3DS Max eyes), as any regular mesh.
So, do that, and then try to add Arnold properties modifier (or any other modifier)
(if it's not working, try first adding edit poly/mesh modifier, and then Arnold properties).
If you cached your particles and you're using Tycache object, disable GPU instancing, and then it should work.
