Cannot Deselect in Select Operator
Hi
As the title says, I have a problem with the Select Operator.
I use it after a Birth Objects and Voronoi Fracture Operators and while I can select Voronoi Fragments just fine I cannot de-select (using the Alt button) some unwanted selections.
Funny thing is that I have used it some time ago and it was working fine. I could select and de-select just fine.
Hmm I can't reproduce this...Alt+select seems to work fine to remove particles from a selection....
Can you try in an empty scene with a fresh flow? Just spawn a few particles and try to select+deselect and see what happens...
(01-27-2023, 02:01 PM)tyFlow Wrote: Hmm I can't reproduce this...Alt+select seems to work fine to remove particles from a selection....
Will try that, thanks.
I made a new scene with a sphere and it worked just fine. Nevertheless in the model that I have in the simulation it just doesn't want to work. It behaves as if the selected particles are non-existent when I try to de-select them. Essentially, I press the Alt key but the cursor never changes when going over any selected particle.
