Position hair - Redshift updating twice on render every time
I am using Ornatrx and tyflow to position particles to the hair, all works great, but when rendering with Redshift, Tyflow has to resim twice each time before it can render for some reason. I know Tyflow is not optimized for redshift so i can't tell if this is somthing that is tyflow or redshift related.
Quote:Tyflow is not optimized for redshift
Hmm, I wouldn't say that. RS's implementation should now be on par with my implementation for all other renderers, including VRay. They all use the same interface now, internally.
The reset sounds like an improper reset notification sent down the pipe somewhere to tyFlow. Whether RS or Ornatrix is sending it remains to be seen (I'd need a file to test). Either way, the easiest workaround would just be to set the flow reset mode to manual, from the editor right click menu. Then it will be guaranteed to not auto-reset no matter which notification comes down the line.
