tyBoolean unstable results
Hello Tyson,
I work a lot with tyBoolean instead of the internal max boolean because it is a modifier. But I have noticed that it sometimes produces unstable results.
Strange thing is that if I put a modifier like "STL Check" above tyBoolean, sometimes the result is changing too. I have attched a simple scene that shows the problem. Please check and uncheck the "STL Check" modifier a few times to see the boolean result changing.
Thank you!
.zip   Files.zip (Size: 359.14 KB / Downloads: 141)
