Vray6 VelocityPass
I just ran a quick test in TYflow and the Vray velocity path is not responding.
In the TYflow setup, I am moving the position, is that bad?
However, the motion blur on the Vray camera is working correctly when turned on.
It is a mysterious phenomenon.
I will send you the file.
Use Vray6 Hotfix3 TyflowPro v1.011
Taking tyCache solved the problem.
However, it is a bit tedious considering that we have to take the cache every time......
.max   vlo_test.max (Size: 984 KB / Downloads: 143)
