Object Bind - strange behaviour
tyflow version v1.0121
3dsMax 2022
Issue: If you set a variation value here inside Dynamic Spring on Object Bind, and then set the mode back to Sticky, it messes all the particles up and they stay messed up after refreshing the flow. Attached file for testing.
[Image: Microsoft-Teams-image-4.png]
.zip   hair_cards_object_bind.zip (Size: 806.15 KB / Downloads: 147)
Ah yes, that value is not supposed to be disabled when switching between modes, because the intention was for it to control variation for all 3 modes (sticky, linear and dynamic).
I will give each mode its own variation so it's less confusing.
(02-16-2023, 01:48 AM)tyFlow Wrote: Ah yes, that value is not supposed to be disabled when switching between modes, because the intention was for it to control variation for all 3 modes (sticky, linear and dynamic).
Thank you, that's great! Much appreciated.
