The display of VDB is no longer updated.
HI,Tyson!
Today, I talked with a friend about VDB. I found tyflow in the test for him_ When VDB read the sequence file, it found a problem that the display of VDB will not be updated after playing it once.
Of course, the "Enable RAM cache" will be automatically updated after it is turned off. I'm not sure if this is your design or a problem.
.mp4   BUG-TEST.mp4 (Size: 7.12 MB / Downloads: 129)
Currently only meshes are cached in the VDB pipeline, so other viewport items like line/point display will only show the result from the last frame simulated.
This might change in the future...it's just that VDBs tend to take a lot of RAM so it's not a good idea to keep a lot of them in memory at the same time.
