03-03-2023, 09:35 AM
Hello, I need help about exporting animated geo in an alembic file.
I use the "birth object" node to create particles, with 3 UVs map channel in source object.
Everything's working fine until the export in alembic which export only the 1st map channel.
I find issue using tymesher, but is there a way to do it with the "Export particles" node ?
Maybe with the pre-export maxscript ?
Thank you for any answer !
