script operator reading an xml
I need a tool to convert Forest from itoo to tyflow.
The forest can export xml file (bellow) with index, witch instance, position rotation and scale (that all I need).
How can I use it in tyflow to create this birth ?
thank you for your help
xml content :
3 instances type, position rotation ans scale
Code:
<ForestData version="1">
    <ForestObject name="Forest001">
        <Item index="0" geomID="0" position="[58.3934,5.85169,0]" scale="[0.89,0.89,0.89]" rotation="[-0.993437,-0.0885635,-0.0723822] [0.0819362,-0.992574,0.0899037] [-0.0798069,0.083383,0.993317] [0,0,0] "/>
        <Item index="1" geomID="0" position="[-73.6066,-5.14831,0]" scale="[0.88,0.88,0.88]" rotation="[0.298131,0.953816,-0.0367879] [-0.95283,0.299676,0.0480516] [0.0568568,0.020727,0.998167] [0,0,0] "/>
        <Item index="2" geomID="0" position="[47.3934,-87.6483,0]" scale="[1.07,1.07,1.07]" rotation="[0.998116,-0.0548769,-0.0274269] [0.0545414,0.998429,-0.0128332] [0.0280881,0.0113131,0.999541] [0,0,0] "/>
        <Item index="3" geomID="0" position="[80.3934,-87.6483,0]" scale="[1.11,1.11,1.11]" rotation="[0.130377,0.990603,0.0413215] [-0.991184,0.131218,-0.0183142] [-0.0235642,-0.0385695,0.998978] [0,0,0] "/>
        <Item index="4" geomID="0" position="[-73.6066,-82.1483,0]" scale="[0.89,0.89,0.89]" rotation="[-0.754267,0.652766,0.070555] [-0.655219,-0.755243,-0.017203] [0.0420566,-0.0592047,0.99736] [0,0,0] "/>
        <Item index="5" geomID="0" position="[63.8934,-43.6483,0]" scale="[0.85,0.85,0.85]" rotation="[-0.626063,-0.779748,-0.00616625] [0.779321,-0.625411,-0.0389963] [0.0265509,-0.0292196,0.99922] [0,0,0] "/>
        <Item index="6" geomID="0" position="[41.8934,-10.6483,0]" scale="[1.12,1.12,1.12]" rotation="[0.0686126,0.996442,0.0489507] [-0.994309,0.0642928,0.0849456] [0.0814962,-0.0545005,0.995182] [0,0,0] "/>
        <Item index="7" geomID="0" position="[-73.6066,11.3517,0]" scale="[1.13,1.13,1.13]" rotation="[0.17605,-0.980161,-0.0910558] [0.98067,0.182659,-0.0701582] [0.0853985,-0.0769443,0.993371] [0,0,0] "/>
        <Item index="8" geomID="0" position="[-24.1066,66.3517,0]" scale="[0.86,0.86,0.86]" rotation="[0.634355,0.773037,0.00256643] [-0.77299,0.634271,0.0136543] [0.0089275,-0.0106455,0.999903] [0,0,0] "/>
        <Item index="9" geomID="0" position="[-18.6066,33.3517,0]" scale="[1.09,1.09,1.09]" rotation="[0.0708306,-0.995531,0.062459] [0.997192,0.072196,0.0198796] [-0.0243001,0.0608755,0.99785] [0,0,0] "/>
        <Item index="10" geomID="0" position="[-62.6066,-38.1483,0]" scale="[0.95,0.95,0.95]" rotation="[-0.691721,0.721823,0.0222016] [-0.717108,-0.690185,0.0969611] [0.085312,0.0511491,0.995041] [0,0,0] "/>
        <Item index="11" geomID="0" position="[47.3934,33.3517,0]" scale="[1.13,1.13,1.13]" rotation="[-0.321645,0.946383,0.0300607] [-0.946296,-0.322387,0.0242932] [0.0326819,-0.0206326,0.999253] [0,0,0] "/>
        <Item index="12" geomID="0" position="[-84.6066,-38.1483,0]" scale="[0.8,0.8,0.8]" rotation="[0.376057,-0.926433,-0.017427] [0.922605,0.376114,-0.0856628] [0.0859154,0.0161358,0.996172] [0,0,0] "/>
        <Item index="13" geomID="0" position="[14.3934,-43.6483,0]" scale="[0.8,0.8,0.8]" rotation="[0.9976,0.0139876,0.0678059] [-0.0102387,0.998416,-0.0553243] [-0.0684724,0.0544973,0.996163] [0,0,0] "/>
        <Item index="14" geomID="0" position="[69.3934,77.3517,0]" scale="[0.96,0.96,0.96]" rotation="[-0.749694,0.661642,0.0137554] [-0.657599,-0.747126,0.0967785] [0.0743097,0.0635087,0.995211] [0,0,0] "/>
        <Item index="15" geomID="0" position="[63.8934,44.3517,0]" scale="[1.05,1.05,1.05]" rotation="[0.718596,0.694675,0.0323472] [-0.694466,0.719271,-0.0191464] [-0.036567,-0.00870546,0.999293] [0,0,0] "/>
        <Item index="16" geomID="0" position="[-24.1066,55.3517,0]" scale="[0.8,0.8,0.8]" rotation="[-0.94829,0.31659,0.0227429] [-0.314154,-0.946393,0.0751523] [0.0453162,0.0641214,0.996913] [0,0,0] "/>
        <Item index="17" geomID="0" position="[80.3934,60.8517,0]" scale="[1.16,1.16,1.16]" rotation="[0.0231877,-0.999614,0.0152715] [0.998079,0.0222688,-0.0578201] [0.0574578,0.0165829,0.99821] [0,0,0] "/>
        <Item index="18" geomID="0" position="[14.3934,-54.6483,0]" scale="[0.97,0.97,0.97]" rotation="[0.67362,0.738088,0.0382297] [-0.735389,0.674522,-0.0649804] [-0.0737481,0.0156584,0.997154] [0,0,0] "/>
        <Item index="19" geomID="0" position="[74.8934,-27.1483,0]" scale="[1.1,1.1,1.1]" rotation="[0.984644,-0.170736,-0.0364172] [0.168865,0.984398,-0.0494482] [0.0442916,0.0425392,0.998113] [0,0,0] "/>
        <Item index="20" geomID="0" position="[-2.10657,16.8517,0]" scale="[1.15,1.15,1.15]" rotation="[0.88531,0.46444,0.0228277] [-0.464932,0.883269,0.0606136] [0.00798836,-0.0642752,0.9979] [0,0,0] "/>
        <Item index="21" geomID="0" position="[14.3934,16.8517,0]" scale="[0.93,0.93,0.93]" rotation="[0.306328,-0.951453,0.0300111] [0.951701,0.306788,0.0120614] [-0.0206829,0.0248669,0.999477] [0,0,0] "/>
        <Item index="22" geomID="0" position="[3.39343,77.3517,0]" scale="[1.15,1.15,1.15]" rotation="[-0.0727774,-0.995338,0.0632896] [0.994757,-0.0770137,-0.0672913] [0.0718518,0.0580604,0.995724] [0,0,0] "/>
        <Item index="23" geomID="0" position="[80.3934,-21.6483,0]" scale="[0.88,0.88,0.88]" rotation="[-0.554244,0.826604,-0.0976766] [-0.827841,-0.559634,-0.0385934] [-0.0865646,0.0594706,0.99447] [0,0,0] "/>
        <Item index="24" geomID="0" position="[-18.6066,55.3517,0]" scale="[0.87,0.87,0.87]" rotation="[0.951268,0.304799,-0.0467691] [-0.302391,0.951756,0.052146] [0.0604069,-0.0354622,0.997544] [0,0,0] "/>
        <Item index="25" geomID="0" position="[41.8934,71.8517,0]" scale="[0.98,0.98,0.98]" rotation="[0.603812,0.796103,0.0403741] [-0.796786,0.604261,0.00136772] [-0.0233076,-0.0329953,0.999184] [0,0,0] "/>
        <Item index="26" geomID="0" position="[69.3934,16.8517,0]" scale="[1.08,1.08,1.08]" rotation="[-0.416589,-0.908572,-0.0308234] [0.909087,-0.416201,-0.0184007] [0.00388966,-0.0356866,0.999355] [0,0,0] "/>
        <Item index="27" geomID="0" position="[41.8934,-16.1483,0]" scale="[0.97,0.97,0.97]" rotation="[0.572397,-0.817917,0.0580826] [0.819852,0.569638,-0.0579147] [0.0142834,0.0807693,0.996631] [0,0,0] "/>
        <Item index="28" geomID="0" position="[-29.6066,0.351692,0]" scale="[1.15,1.15,1.15]" rotation="[0.35909,0.930462,0.0727701] [-0.931539,0.362111,-0.03331] [-0.0573446,-0.0558269,0.996792] [0,0,0] "/>
        <Item index="29" geomID="0" position="[14.3934,71.8517,0]" scale="[0.94,0.94,0.94]" rotation="[-0.0281274,0.997951,-0.0574652] [-0.997782,-0.0314993,-0.0586404] [-0.0603303,0.0556883,0.996624] [0,0,0] "/>
        <Item index="30" geomID="0" position="[58.3934,-32.6483,0]" scale="[0.88,0.88,0.88]" rotation="[-0.324912,-0.945682,0.0108497] [0.941956,-0.324616,-0.0856914] [0.0845588,-0.0176222,0.996263] [0,0,0] "/>
        <Item index="31" geomID="0" position="[8.89343,-32.6483,0]" scale="[1.01,1.01,1.01]" rotation="[0.901392,0.426652,-0.0739009] [-0.42713,0.904135,0.0100048] [0.0710849,0.022547,0.997215] [0,0,0] "/>
        <Item index="32" geomID="0" position="[-46.1066,5.85169,0]" scale="[1.13,1.13,1.13]" rotation="[0.806063,0.591606,0.0162553] [-0.59182,0.805904,0.0163622] [-0.00342028,-0.0228091,0.999734] [0,0,0] "/>
        <Item index="33" geomID="0" position="[-35.1066,22.3517,0]" scale="[0.98,0.98,0.98]" rotation="[0.99189,-0.123285,-0.0308934] [0.120416,0.989336,-0.0819358] [0.0406655,0.0775513,0.996159] [0,0,0] "/>
        <Item index="34" geomID="0" position="[-24.1066,5.85169,0]" scale="[0.8,0.8,0.8]" rotation="[0.744204,0.666225,-0.047997] [-0.667945,0.741949,-0.0579671] [-0.00300778,0.0751988,0.997164] [0,0,0] "/>
        <Item index="35" geomID="0" position="[3.39343,5.85169,0]" scale="[0.89,0.89,0.89]" rotation="[0.205789,-0.976278,-0.0673281] [0.975058,0.210404,-0.0706483] [0.0831385,-0.0511102,0.995226] [0,0,0] "/>
        <Item index="36" geomID="0" position="[30.8934,22.3517,0]" scale="[0.99,0.99,0.99]" rotation="[-0.979505,0.201142,-0.0105638] [-0.200102,-0.97775,-0.0629568] [-0.022992,-0.0595526,0.99796] [0,0,0] "/>
        <Item index="37" geomID="0" position="[-7.60657,-5.14831,0]" scale="[0.99,0.99,0.99]" rotation="[0.656159,0.754268,0.0231573] [-0.752266,0.651378,0.099007] [0.0595936,-0.0823848,0.994817] [0,0,0] "/>
        <Item index="38" geomID="1" position="[-7.60657,-82.1483,0]" scale="[1.16,1.16,1.16]" rotation="[-0.584612,-0.808605,0.0662391] [0.808651,-0.587357,-0.0331042] [0.0656742,0.0342112,0.997254] [0,0,0] "/>
        <Item index="39" geomID="1" position="[-68.1066,33.3517,0]" scale="[0.92,0.92,0.92]" rotation="[0.999498,-0.030455,0.00871638] [0.0307133,0.999041,-0.0312221] [-0.00775715,0.0314741,0.999474] [0,0,0] "/>
        <Item index="40" geomID="1" position="[-35.1066,33.3517,0]" scale="[0.87,0.87,0.87]" rotation="[-0.176019,0.984257,0.0160127] [-0.981466,-0.174221,-0.0798166] [-0.0757703,-0.0297652,0.996681] [0,0,0] "/>
        <Item index="41" geomID="1" position="[52.8934,38.8517,0]" scale="[0.9,0.9,0.9]" rotation="[-0.937748,-0.345535,0.0351432] [0.34536,-0.938404,-0.0111152] [0.0368192,0.00171384,0.99932] [0,0,0] "/>
        <Item index="42" geomID="1" position="[80.3934,-65.6483,0]" scale="[0.85,0.85,0.85]" rotation="[-0.771928,-0.633944,0.0473604] [0.63063,-0.77303,-0.0687743] [0.0802101,-0.0232218,0.996507] [0,0,0] "/>
        <Item index="43" geomID="1" position="[-40.6066,-54.6483,0]" scale="[0.9,0.9,0.9]" rotation="[0.529608,0.848143,-0.0130009] [-0.847585,0.529738,0.0312622] [0.0334019,-0.00553732,0.999427] [0,0,0] "/>
        <Item index="44" geomID="1" position="[-29.6066,-54.6483,0]" scale="[1.05,1.05,1.05]" rotation="[0.00919489,0.999913,-0.00946511] [-0.999929,0.00926645,0.00754486] [0.00763191,0.00939506,0.999927] [0,0,0] "/>
        <Item index="45" geomID="1" position="[-35.1066,-49.1483,0]" scale="[1.13,1.13,1.13]" rotation="[-0.44251,0.896454,0.0235705] [-0.89644,-0.442903,0.0152213] [0.0240847,-0.014394,0.999606] [0,0,0] "/>
        <Item index="46" geomID="1" position="[-84.6066,-21.6483,0]" scale="[1.07,1.07,1.07]" rotation="[-0.83906,0.543859,-0.0139762] [-0.543982,-0.838326,0.0359579] [0.00783944,0.0377736,0.999256] [0,0,0] "/>
        <Item index="47" geomID="1" position="[74.8934,-21.6483,0]" scale="[0.93,0.93,0.93]" rotation="[-0.994936,-0.0994673,-0.014431] [0.099069,-0.994738,0.0260959] [-0.0169508,0.0245341,0.999555] [0,0,0] "/>
        <Item index="48" geomID="1" position="[3.39343,-16.1483,0]" scale="[1.12,1.12,1.12]" rotation="[-0.952542,-0.297894,-0.0626389] [0.296682,-0.954565,0.0280374] [-0.068145,0.00812291,0.997642] [0,0,0] "/>
        <Item index="49" geomID="1" position="[19.8934,-16.1483,0]" scale="[1.11,1.11,1.11]" rotation="[0.62475,0.780788,-0.00762909] [-0.779779,0.623378,-0.0578235] [-0.0403921,0.0420743,0.998298] [0,0,0] "/>
        <Item index="50" geomID="1" position="[25.3934,-16.1483,0]" scale="[0.98,0.98,0.98]" rotation="[0.356718,0.932562,-0.0554994] [-0.932806,0.352293,-0.0759147] [-0.0512431,0.0788503,0.995569] [0,0,0] "/>
        <Item index="51" geomID="1" position="[19.8934,0.351692,0]" scale="[0.93,0.93,0.93]" rotation="[0.749018,0.655752,0.0946672] [-0.658909,0.752217,0.00281722] [-0.0693629,-0.0644872,0.995505] [0,0,0] "/>
        <Item index="52" geomID="1" position="[-35.1066,5.85169,0]" scale="[1.15,1.15,1.15]" rotation="[0.995459,0.0901408,0.0306006] [-0.0910454,0.995407,0.0295823] [-0.0277935,-0.032234,0.999094] [0,0,0] "/>
        <Item index="53" geomID="1" position="[41.8934,5.85169,0]" scale="[0.85,0.85,0.85]" rotation="[0.292705,-0.954379,0.0590336] [0.954985,0.294889,0.0323019] [-0.0482366,0.0469213,0.997733] [0,0,0] "/>
        <Item index="54" geomID="1" position="[-18.6066,11.3517,0]" scale="[1.16,1.16,1.16]" rotation="[-0.314064,-0.948967,-0.0287318] [0.948882,-0.31475,0.0235808] [-0.0314207,-0.0198572,0.999309] [0,0,0] "/>
        <Item index="55" geomID="1" position="[-68.1066,16.8517,0]" scale="[1.09,1.09,1.09]" rotation="[-0.696374,-0.715766,0.0523566] [0.712471,-0.698252,-0.0695002] [0.086304,-0.0110956,0.996207] [0,0,0] "/>
        <Item index="56" geomID="1" position="[-51.6066,16.8517,0]" scale="[0.85,0.85,0.85]" rotation="[0.327898,-0.942562,-0.0637237] [0.944563,0.328303,0.00430158] [0.0168662,-0.0616015,0.997958] [0,0,0] "/>
        <Item index="57" geomID="1" position="[-7.60657,16.8517,0]" scale="[1.11,1.11,1.11]" rotation="[-0.780109,-0.625388,-0.0178752] [0.624737,-0.777123,-0.0760486] [0.0336687,-0.0704935,0.996944] [0,0,0] "/>
        <Item index="58" geomID="1" position="[52.8934,16.8517,0]" scale="[1.2,1.2,1.2]" rotation="[0.262156,-0.963265,0.0582685] [0.962211,0.256306,-0.0919571] [0.0736445,0.0801736,0.994057] [0,0,0] "/>
        <Item index="59" geomID="1" position="[47.3934,27.8517,0]" scale="[0.86,0.86,0.86]" rotation="[-0.674601,-0.734105,0.0774827] [0.734093,-0.678191,-0.0341173] [0.0775938,0.0338639,0.99641] [0,0,0] "/>
        <Item index="60" geomID="1" position="[-79.1066,-65.6483,0]" scale="[0.82,0.82,0.82]" rotation="[0.888551,0.458498,0.016044] [-0.458586,0.888648,0.00206595] [-0.0133102,-0.00919324,0.999869] [0,0,0] "/>
        <Item index="61" geomID="1" position="[-73.6066,-65.6483,0]" scale="[0.89,0.89,0.89]" rotation="[-0.618085,0.785062,0.0406008] [-0.785519,-0.614789,-0.0706706] [-0.0305199,-0.0755731,0.996673] [0,0,0] "/>
        <Item index="62" geomID="1" position="[-46.1066,-65.6483,0]" scale="[1.02,1.02,1.02]" rotation="[0.893882,-0.448109,-0.0131536] [0.448302,0.893454,0.0276742] [-0.00064896,-0.0306343,0.99953] [0,0,0] "/>
        <Item index="63" geomID="1" position="[25.3934,-71.1483,0]" scale="[0.99,0.99,0.99]" rotation="[0.960517,0.278011,-0.0108146] [-0.278218,0.959964,-0.0326272] [0.00131094,0.0343478,0.999409] [0,0,0] "/>
        <Item index="64" geomID="1" position="[-57.1066,-60.1483,0]" scale="[1.08,1.08,1.08]" rotation="[-0.985767,0.141094,-0.0914055] [-0.143972,-0.989249,0.025664] [-0.0868017,0.0384586,0.995483] [0,0,0] "/>
        <Item index="65" geomID="1" position="[-51.6066,-60.1483,0]" scale="[0.91,0.91,0.91]" rotation="[-0.883332,-0.467744,0.0306561] [0.468697,-0.880381,0.0724738] [-0.00691019,0.0783869,0.996899] [0,0,0] "/>
        <Item index="66" geomID="1" position="[-7.60657,-60.1483,0]" scale="[1.04,1.04,1.04]" rotation="[0.385181,0.921537,0.0490497] [-0.922322,0.382638,0.053953] [0.0309514,-0.0660213,0.997338] [0,0,0] "/>
        <Item index="67" geomID="1" position="[-7.60657,60.8517,0]" scale="[1.11,1.11,1.11]" rotation="[0.844238,0.527239,0.0963429] [-0.528944,0.848609,-0.0089727] [-0.0864882,-0.043385,0.995308] [0,0,0] "/>
        <Item index="68" geomID="1" position="[-13.1066,44.3517,0]" scale="[0.97,0.97,0.97]" rotation="[0.872245,-0.480398,0.0916835] [0.482612,0.875832,-0.00226494] [-0.0792112,0.0462231,0.995786] [0,0,0] "/>
        <Item index="69" geomID="1" position="[63.8934,49.8517,0]" scale="[0.9,0.9,0.9]" rotation="[-0.220187,-0.975397,-0.0108546] [0.975077,-0.220399,0.0254715] [-0.0272372,-0.00497553,0.999617] [0,0,0] "/>
        <Item index="70" geomID="1" position="[-79.1066,66.3517,0]" scale="[0.87,0.87,0.87]" rotation="[-0.626291,0.779586,-0.00217636] [-0.77919,-0.625878,0.0337743] [0.0249678,0.0228483,0.999427] [0,0,0] "/>
        <Item index="71" geomID="1" position="[-62.6066,71.8517,0]" scale="[1.19,1.19,1.19]" rotation="[-0.769018,0.639217,-0.00359603] [-0.63728,-0.767101,-0.0736928] [-0.0498643,-0.0543794,0.997275] [0,0,0] "/>
        <Item index="72" geomID="1" position="[-13.1066,71.8517,0]" scale="[0.81,0.81,0.81]" rotation="[0.338095,0.93985,-0.0487229] [-0.940465,0.335489,-0.0545241] [-0.0348984,0.0642565,0.997323] [0,0,0] "/>
        <Item index="73" geomID="1" position="[-2.10657,77.3517,0]" scale="[0.8,0.8,0.8]" rotation="[0.997645,-0.0634744,0.0259991] [0.0627983,0.997686,0.0260447] [-0.0275921,-0.0243506,0.999323] [0,0,0] "/>
        <Item index="74" geomID="1" position="[14.3934,77.3517,0]" scale="[1.01,1.01,1.01]" rotation="[-0.512515,-0.853346,0.0955429] [0.856706,-0.5157,-0.0104213] [0.0581645,0.076511,0.995371] [0,0,0] "/>
        <Item index="75" geomID="1" position="[58.3934,-71.1483,0]" scale="[1.11,1.11,1.11]" rotation="[-0.797174,0.602923,0.0315773] [-0.603114,-0.797644,0.00414927] [0.0276892,-0.015737,0.999493] [0,0,0] "/>
        <Item index="76" geomID="1" position="[80.3934,-71.1483,0]" scale="[0.97,0.97,0.97]" rotation="[-0.927107,0.374694,0.00880513] [-0.374299,-0.92683,0.0297672] [0.0193144,0.0243016,0.999518] [0,0,0] "/>
        <Item index="77" geomID="1" position="[-84.6066,-27.1483,0]" scale="[0.83,0.83,0.83]" rotation="[0.798051,-0.601777,0.0312996] [0.599788,0.798271,0.0549339] [-0.0580435,-0.0250669,0.997999] [0,0,0] "/>
        <Item index="78" geomID="1" position="[19.8934,-43.6483,0]" scale="[0.83,0.83,0.83]" rotation="[0.99724,0.0741158,-0.00445073] [-0.0741565,0.997198,-0.00979848] [0.00371204,0.0101015,0.999942] [0,0,0] "/>
        <Item index="79" geomID="1" position="[47.3934,-43.6483,0]" scale="[1.08,1.08,1.08]" rotation="[0.359853,-0.932208,-0.0386441] [0.933009,0.359523,0.0154138] [-0.000475466,-0.041602,0.999134] [0,0,0] "/>
        <Item index="80" geomID="1" position="[-68.1066,-38.1483,0]" scale="[0.92,0.92,0.92]" rotation="[0.826517,0.560231,-0.0548634] [-0.562126,0.826581,-0.0278938] [0.0297221,0.0538948,0.998104] [0,0,0] "/>
        <Item index="81" geomID="1" position="[58.3934,-38.1483,0]" scale="[1.19,1.19,1.19]" rotation="[0.165355,0.986206,0.00743308] [-0.986167,0.165252,0.0128794] [0.0114734,-0.00945993,0.999889] [0,0,0] "/>
        <Item index="82" geomID="1" position="[74.8934,-38.1483,0]" scale="[1.17,1.17,1.17]" rotation="[0.204003,0.978465,0.031458] [-0.977634,0.20194,0.0587545] [0.0511365,-0.0427405,0.997777] [0,0,0] "/>
        <Item index="83" geomID="1" position="[25.3934,-10.6483,0]" scale="[1.05,1.05,1.05]" rotation="[-0.940651,0.330281,0.0780353] [-0.332511,-0.942943,-0.0171814] [0.0679081,-0.0421093,0.996803] [0,0,0] "/>
        <Item index="84" geomID="1" position="[58.3934,-10.6483,0]" scale="[0.99,0.99,0.99]" rotation="[0.58267,-0.812654,0.00937985] [0.810929,0.582119,0.0594329] [-0.0537586,-0.0270234,0.998188] [0,0,0] "/>
        <Item index="85" geomID="1" position="[-57.1066,-5.14831,0]" scale="[1.14,1.14,1.14]" rotation="[0.494258,-0.869312,0.00241409] [0.867359,0.49333,0.0656865] [-0.058293,-0.0303722,0.997837] [0,0,0] "/>
        <Item index="86" geomID="1" position="[-46.1066,-87.6483,0]" scale="[1.13,1.13,1.13]" rotation="[-0.999958,0.00774022,-0.00482173] [-0.00736258,-0.997235,-0.0739451] [-0.00538075,-0.0739065,0.997251] [0,0,0] "/>
        <Item index="87" geomID="1" position="[19.8934,-5.14831,0]" scale="[0.91,0.91,0.91]" rotation="[0.941048,0.334118,-0.0528506] [-0.329109,0.940432,0.0852922] [0.0782,-0.0628705,0.994953] [0,0,0] "/>
        <Item index="88" geomID="2" position="[25.3934,16.8517,0]" scale="[1.02,1.02,1.02]" rotation="[0.851249,0.523933,0.0294767] [-0.524755,0.850182,0.0426891] [-0.00269435,-0.0518071,0.998653] [0,0,0] "/>
        <Item index="89" geomID="2" position="[-51.6066,44.3517,0]" scale="[0.85,0.85,0.85]" rotation="[0.250516,0.968065,0.00954342] [-0.967809,0.250179,0.0274886] [0.0242232,-0.0161226,0.999577] [0,0,0] "/>
        <Item index="90" geomID="2" position="[25.3934,11.3517,0]" scale="[1.15,1.15,1.15]" rotation="[0.931573,-0.357385,-0.0666947] [0.360447,0.931871,0.0411741] [0.0474358,-0.0623965,0.996924] [0,0,0] "/>
        <Item index="91" geomID="2" position="[41.8934,-76.6483,0]" scale="[0.87,0.87,0.87]" rotation="[0.116361,-0.990177,-0.0775245] [0.992919,0.114095,0.0330688] [-0.0238988,-0.0808235,0.996442] [0,0,0] "/>
        <Item index="92" geomID="2" position="[63.8934,-76.6483,0]" scale="[1.19,1.19,1.19]" rotation="[-0.872265,-0.484264,-0.0681384] [0.481633,-0.874833,0.0519253] [-0.0847553,0.0124749,0.996324] [0,0,0] "/>
        <Item index="93" geomID="2" position="[80.3934,-76.6483,0]" scale="[0.94,0.94,0.94]" rotation="[0.813124,0.581906,0.0146532] [-0.581804,0.813256,-0.0109287] [-0.0182763,0.000361047,0.999833] [0,0,0] "/>
        <Item index="94" geomID="2" position="[-18.6066,-71.1483,0]" scale="[0.93,0.93,0.93]" rotation="[0.99751,-0.0207484,0.0674068] [0.017663,0.998783,0.0460507] [-0.0682803,-0.0447454,0.996662] [0,0,0] "/>
        <Item index="95" geomID="2" position="[14.3934,-71.1483,0]" scale="[0.89,0.89,0.89]" rotation="[0.0133549,-0.99991,0.000886033] [0.997845,0.0133842,0.0642292] [-0.0642353,2.63503e-05,0.997935] [0,0,0] "/>
        <Item index="96" geomID="2" position="[-84.6066,11.3517,0]" scale="[0.9,0.9,0.9]" rotation="[-0.722064,0.690912,-0.0355449] [-0.69155,-0.722275,0.00885175] [-0.0195574,0.0309726,0.999329] [0,0,0] "/>
        <Item index="97" geomID="2" position="[-24.1066,44.3517,0]" scale="[1.2,1.2,1.2]" rotation="[-0.803536,0.594773,-0.0239566] [-0.595252,-0.802744,0.0357462] [0.0020299,0.0429836,0.999074] [0,0,0] "/>
        <Item index="98" geomID="2" position="[-2.10657,-65.6483,0]" scale="[1,1,1]" rotation="[0.768596,0.639193,0.0263092] [-0.639725,0.767715,0.0369599] [0.00342649,-0.0452379,0.99897] [0,0,0] "/>
        <Item index="99" geomID="2" position="[-68.1066,5.85169,0]" scale="[1.05,1.05,1.05]" rotation="[0.945693,0.321187,-0.0500325] [-0.320603,0.947013,0.019495] [0.0536429,-0.00239576,0.998557] [0,0,0] "/>
        <Item index="100" geomID="2" position="[74.8934,0.351692,0]" scale="[1.07,1.07,1.07]" rotation="[0.783332,-0.618105,-0.0658577] [0.617183,0.785996,-0.0359741] [0.0739997,-0.0124667,0.99718] [0,0,0] "/>
        <Item index="101" geomID="2" position="[74.8934,-32.6483,0]" scale="[0.99,0.99,0.99]" rotation="[-0.989545,0.135724,0.0487918] [-0.138973,-0.987756,-0.0708791] [0.0385745,-0.0769187,0.996291] [0,0,0] "/>
        <Item index="102" geomID="2" position="[-73.6066,27.8517,0]" scale="[0.88,0.88,0.88]" rotation="[0.63712,-0.770518,0.0194838] [0.766913,0.636258,0.0837813] [-0.0769517,-0.0384364,0.996294] [0,0,0] "/>
        <Item index="103" geomID="2" position="[-57.1066,-27.1483,0]" scale="[0.88,0.88,0.88]" rotation="[0.258293,0.962229,-0.0860212] [-0.965444,0.260297,0.0127631] [0.0346721,0.0797521,0.996212] [0,0,0] "/>
        <Item index="104" geomID="2" position="[63.8934,-54.6483,0]" scale="[0.82,0.82,0.82]" rotation="[-0.910784,0.409177,0.0551944] [-0.410518,-0.911727,-0.0151442] [0.0441255,-0.0364514,0.998361] [0,0,0] "/>
        <Item index="105" geomID="2" position="[-84.6066,-43.6483,0]" scale="[1.13,1.13,1.13]" rotation="[0.984023,0.170593,-0.0509593] [-0.16663,0.983244,0.0739297] [0.0627173,-0.0642572,0.995961] [0,0,0] "/>
        <Item index="106" geomID="2" position="[-68.1066,-43.6483,0]" scale="[0.92,0.92,0.92]" rotation="[-0.934641,0.354487,-0.0280115] [-0.352676,-0.934164,-0.0543791] [-0.045444,-0.040946,0.998127] [0,0,0] "/>
        <Item index="107" geomID="2" position="[-7.60657,38.8517,0]" scale="[1.17,1.17,1.17]" rotation="[0.151456,0.988399,0.0113395] [-0.98473,0.15187,-0.0850982] [-0.0858332,0.00172221,0.996308] [0,0,0] "/>
        <Item index="108" geomID="2" position="[3.39343,-65.6483,0]" scale="[0.99,0.99,0.99]" rotation="[-0.937426,0.347448,-0.0226525] [-0.346221,-0.937063,-0.045199] [-0.0369311,-0.0345279,0.998721] [0,0,0] "/>
        <Item index="109" geomID="2" position="[74.8934,60.8517,0]" scale="[0.89,0.89,0.89]" rotation="[0.0150033,0.999614,-0.0234033] [-0.997258,0.0166562,0.0721061] [0.0724681,0.0222573,0.997122] [0,0,0] "/>
        <Item index="110" geomID="2" position="[52.8934,-43.6483,0]" scale="[1.12,1.12,1.12]" rotation="[-0.988734,0.149658,-0.00264465] [-0.149553,-0.988464,-0.0239357] [-0.00619633,-0.0232706,0.99971] [0,0,0] "/>
        <Item index="111" geomID="2" position="[-51.6066,-54.6483,0]" scale="[1.05,1.05,1.05]" rotation="[0.845322,0.529435,-0.0716225] [-0.532393,0.845958,-0.0302058] [0.0445976,0.0636649,0.996974] [0,0,0] "/>
        <Item index="112" geomID="2" position="[-40.6066,38.8517,0]" scale="[0.8,0.8,0.8]" rotation="[0.376266,-0.922515,-0.0859596] [0.923448,0.380943,-0.0461059] [0.0752791,-0.0620312,0.995231] [0,0,0] "/>
        <Item index="113" geomID="2" position="[63.8934,22.3517,0]" scale="[0.96,0.96,0.96]" rotation="[-0.202254,-0.979291,-0.00905062] [0.976807,-0.20106,-0.0736367] [0.0702921,-0.023734,0.997244] [0,0,0] "/>
        <Item index="114" geomID="2" position="[30.8934,33.3517,0]" scale="[0.84,0.84,0.84]" rotation="[0.999044,0.0223364,-0.0375758] [-0.019111,0.996273,0.084108] [0.0393144,-0.0833095,0.995748] [0,0,0] "/>
        <Item index="115" geomID="2" position="[-13.1066,-38.1483,0]" scale="[0.9,0.9,0.9]" rotation="[-0.920853,0.382792,0.0741668] [-0.380962,-0.92381,0.0379797] [0.0830544,0.0067189,0.996522] [0,0,0] "/>
        <Item index="116" geomID="2" position="[-68.1066,71.8517,0]" scale="[1.17,1.17,1.17]" rotation="[-0.0553314,-0.998448,-0.0063816] [0.99832,-0.0554323,0.0168866] [-0.0172142,-0.00543652,0.999837] [0,0,0] "/>
        <Item index="117" geomID="2" position="[-29.6066,-65.6483,0]" scale="[1.13,1.13,1.13]" rotation="[-0.201782,-0.975905,0.0830275] [0.97741,-0.206083,-0.0468963] [0.0628769,0.0716891,0.995443] [0,0,0] "/>
        <Item index="118" geomID="2" position="[-35.1066,-10.6483,0]" scale="[0.82,0.82,0.82]" rotation="[-0.857674,0.513813,0.0197716] [-0.513596,-0.857898,0.0151924] [0.0247681,0.00287548,0.999689] [0,0,0] "/>
        <Item index="119" geomID="2" position="[-73.6066,44.3517,0]" scale="[1.13,1.13,1.13]" rotation="[0.955628,-0.291914,-0.0395096] [0.290385,0.956065,-0.0401963] [0.0495076,0.0269397,0.99841] [0,0,0] "/>
        <Item index="120" geomID="2" position="[3.39343,-82.1483,0]" scale="[1.09,1.09,1.09]" rotation="[-0.832326,0.544894,-0.101605] [-0.548719,-0.83592,0.0120681] [-0.0783582,0.0657974,0.994752] [0,0,0] "/>
        <Item index="121" geomID="2" position="[-51.6066,22.3517,0]" scale="[1,1,1]" rotation="[0.722843,0.683434,-0.102059] [-0.686102,0.727411,0.0116896] [0.0822279,0.0615731,0.99471] [0,0,0] "/>
        <Item index="122" geomID="2" position="[69.3934,-10.6483,0]" scale="[0.97,0.97,0.97]" rotation="[0.849767,-0.523929,-0.0582689] [0.52686,0.847803,0.0604098] [0.01775,-0.0820338,0.996471] [0,0,0] "/>
        <Item index="123" geomID="2" position="[19.8934,-87.6483,0]" scale="[0.82,0.82,0.82]" rotation="[0.955157,-0.296097,0.00132961] [0.295839,0.954118,-0.0462419] [0.0124235,0.0445616,0.998929] [0,0,0] "/>
        <Item index="124" geomID="2" position="[63.8934,16.8517,0]" scale="[1.18,1.18,1.18]" rotation="[0.795526,0.600874,0.078031] [-0.600983,0.79888,-0.0247109] [-0.0771855,-0.0272372,0.996645] [0,0,0] "/>
        <Item index="125" geomID="2" position="[74.8934,71.8517,0]" scale="[1.19,1.19,1.19]" rotation="[0.437535,-0.897625,-0.0532146] [0.897777,0.439406,-0.0303047] [0.050585,-0.0345155,0.998123] [0,0,0] "/>
        <Item index="126" geomID="2" position="[-68.1066,44.3517,0]" scale="[0.86,0.86,0.86]" rotation="[-0.74908,-0.661509,-0.035851] [0.66247,-0.748263,-0.0351573] [-0.00356917,-0.0500858,0.998739] [0,0,0] "/>
    </ForestObject>
</ForestData>
tyFlow's Script operator just uses regular C#, so you could try following these instructions:
https://stackoverflow.com/questions/6422...-file-in-c
Note that 3ds Max's bundled C# assemblies don't include System.Xml.dll, so you'd have to find that elsewhere and bring it into the Script operator as a custom assembly (add it to the assemblies list in the settings).
If your machine has .Net 4 installed, you can find it in the .Net 4 installation folder.
