tyflow not binding to mesh boxes (conveyer)
I have a bunch of boxes following the path. Tyflow bind to surface is not binding well to those boxes. We want to create conveyor belt surface.   is it a bug? Thanks  attached the scene
Do this instead: disable your Element Fracture and Object Bind operators, and instead enable the object animation options in the Birth Objects operator (inherit position/rotation).
The fix for your current setup is setting the Object Bind sample to 'Face' instead of 'Hybrid'....when you have multiple low-res objects as input, the 'Hybrid' mode can accidentally bind your particles to the wrong part of the surface, resulting in the issues that you see.
