What could cause a material being "stuck" to a system? I'm trying to apply a different material to a tyFlow but it's not being applied. Even if I apply it, close then open max again, still not updated.
Originally I was having trouble getting the Shell edge material IDs to render properly in VRay. I can't even troubleshoot it because of the above problem.
Edit: This is weird .... interactive rendering in the VRay Frame Buffer shows the correct material and material IDs. But render does not.
