tyCache Cull by ID doesn't work
It appears the tyCache Cull by ID input field does not retain user input and always resets to a blank input field. I'm on max 2023 and tyFlow v1.020.
Scott
Hmm, could be a regression. I'll look into it, thanks.
Indeed, it's a regression introduced in 1.020. If you need the functionality ASAP, you can revert to a previous build, but the fix should be out soon.
Exclamation
Is this still a problem?
I'm having a problem with the particle not Culling/deleting?
Even if i reload the entire TyCache
