tyflow keyboard shortcut
Can I apply the delete shortcut?
PF particle is deleted with shortcut key set in 3ds max, but tyflow is not applied with shortcut key set in operator delete in 3ds max.
Can you make it work?
What do you mean "PF particle is deleted with shortcut key"?
For example, my 3ds max removal shortcut is 'D'.
In pfparticle, operator removal was possible with the D shortcut.
However, the tyflow operator is not removed by D.
I hope it works with the 3ds max keyboard shortcut.
tyFlow shortcuts are currently hard-coded and not assignable. You can press the 'del' key to delete a selected operator.
Okay, thank you
Remove operator instead of delete key
I hope there is an easy way to remove it in another way.
The delete key is too far away.way.[/font][/size][/color]
