Script working in TyFlow 1.0.19 but not BETA
I have a script that's working just fine in 1.0.19 (it's just in a script operator with some custom floats, nothing fancy). But I need to use the beta for a project and I can't seem to figure out why the script isn't working- I've checked the update logs and API changes and everything seems to me like it should work just fine.
Sorry if you don't provide beta support, I just figured I'd ask anyways in case someone knows! The script is attached below. Maybe some syntax change? Confused
Thanks a bunch,
Sean
.txt   ScaleByTexture.txt (Size: 2.18 KB / Downloads: 236)
Well I solved it! Turns out it was an issue with evaluation priority on the overall event, not the script itself. So ignore this Big Grin
