Hi, I need help to understand if tyflow can do one task that is in my head, and if yes - help how to do it)))
So.
I have a volume. it consist of triangles.
I need faces inset n side a bit. than on inseted faces should be scattered spheres. amount of spheres should go from bottom to top with gradient map ( top 100%, bottom 0%). On some faces there should be no spheres. Speheres should not intersect with each other and do not go out of face.
Than from original volume - boolean to make holes with help of those spheres.
So.
