tyselect - curvature flickering with vertex color
hey there, when I convert the tyselect curvature to vertex color, the dark areas flickers a lot continously(especially when fall off is assigned).....while if the same thing I do with data channel curvature, its super smooth.....
How can I stop flickering in curvature
Here's an attachment showing the difference in curvature selection.....left is data channel and right is tyselect. you can clearly see the difference in smoothness...
Can you post the file?
Here's the file
.max   Curvature_2024.max (Size: 1,020 KB / Downloads: 186)
(11-03-2023, 05:44 PM)tyFlow Wrote: Can you post the file?
Hey there, Did you check the file?
I haven't had a chance to look at it yet, no. I'll try to look at it today.
Thanks for the file, should be improved in the next build:
.mp4   Curvature_2024_Orthographic_preview_v001.mp4 (Size: 1.14 MB / Downloads: 167)
(11-07-2023, 06:59 PM)tyFlow Wrote: Thanks for the file, should be improved in the next build:
Thank you
