12-13-2023, 02:02 PM
Hey,
I've seen similar topics about the question, but did not find any solution to the problem.
I have a scene where I want to us tyflow to born small plans with animated bitmap textures (distant, small explosions in this case), and want to render it on GPU. I've noticed tyBitmap is not compatibile with VRay GPU engine, I'm looking for a solution to use animated bitmaps with it. Does it have some kind of workaround, or should I switch to CPU engine (would be better to not) to use animation in such way?
Thank you!
Thank you!
