04-17-2019, 06:46 AM
an example:
modify bindings/cloth/inflation force..
its in scene units. a setting of 5mm at 1/4 timestep gives a completely different result to 5mm at 1/8 timestep.
given we normally do tests at a longer timestep, and reduce it when necessary during the project, this is quite annoying!
i assume its 5mm *per step* which means, 1/8 will require a setting of 2.5mm to be equivalent?
if it works like this, can we have a tickbox which links settings to timestep and automatically changes all relevant settings to get similar result at different timesteps?
thanks!
thanks!
