04-17-2019, 09:31 AM
New version is out:
http://beta.tyflow.com
This features some critical bugfixes so please make sure you've updated
Some people were reporting that their PhoenixFD operators would cause tyFlow to hang/crash in previous versions. Please test to see if the problem is solved in this version.
* rebuilt with latest PhoenixFD libraries
* fixed a critical bug that was causing full flow corruption when outputting particles from a Voronoi Fracture operator (resulted in intermittent particle disappearances)
* fixed a bug that was preventing PhysX shapes from inheriting proper particle velocities and forces when simulation timestep is less than 1
* tyFlow should now appear in proper 'standard primitives' location in non-english versions of 3dsmax
* fixed a bug where tyFlow would crash if "print calculation times" was enabled in the tyCarve modifier
* fixed a bug where resample operator was not properly integrating affected particle velocities
* fixed a bug that would cause Actor Collect to crash when it doesn't have an output operator.
